Please note we will periodically update this post with new information, so the content here may change. Please post issues or comments related to the topics mentioned in this post in the thread below.
If you have GPU issues or comment unrelated to the items in this post, please start a new post in General Support.
KeyShot 9 will detect the current driver you have installed and alert you if the driver is known to be incompatible or lack feature support.
With the first release of KeyShot 9 the most recent drivers from NVIDIA will tell you upon loading that there are known issues and to drop back to an earlier release. This is not required, the newer driver(s) can be used, however certain material types may display incorrectly, hence the warning.
The driver compatibility information will be updated inside of KeyShot 9 as new drivers are released, as long as you are connected to the Internet.
Current Approved Driver Version Tested in QA: Driver 441.66
Francisco Carrera
https://www.nvidia.com/Download/Find.aspx?lang=en-us
Notes:
