Has anyone noticed the Color Picker Tool doesn't function outside the KeyShot window? I've noticed this on every update since 9 was released.
Best Answer
N
Niko Planke
said
almost 3 years ago
The Color Picker Tool will not work outside of KeyShot on MacOS Catalina if it does not have permission to record the screen. MacOS should give you a warning the first time you use the tool, but if you did not enable it then, you can enable it in System Preferences > Security & Privacy > Privacy > Screen Recording. Click on the lock to make changes and enable KeyShot.
1 Comment
N
Niko Planke
said
almost 3 years ago
Answer
ePluribusBigly
Niko Planke
Keyshot 8.2.80 / Out of memory (requesting 4294967214MB) This may cause instabilities
PSD Screenshot gives program error in Photoshop
Accessing Context Menu in KS 9.1.98 with single button mouse
Critical Bug by 3dsMax plugin
Can't Drag Materials from Cloud Library
Crash on “Finishing” after rendering animation
Not able to export FUZZ Geometry to FBX/OBJ
Cuda error: cudaErrorDevicesUnavailable (all CUDA-capable devices are busy or unavailable) Device : GeForce GTX 1070
See all 104 topics
