When saving a screenshot in PSD format, the resulting file cannot be opened in Photoshop. It gives a "Could not open "FILE" because of a program error.
I'm using KeyShot 9.0, and replicated the issue on both Mac OS 10.15.3 & Windows 10. Any screenshot (regardless of what's visible) gives unusable files.
No extra steps needed other than simply trying to save a PSD screenshot (with our without transparency).
Best Answer
Q
QA Team
said
about 1 year ago
Hi Richard,
Thank you for reporting this bug to us.
I will make sure to pass it along to the developers.
A few things you can do as a work around is to save the image as a different image file (png,jpg etc)
I found this give no errors.
Also you can try to render the image out instead of a screen grab as a psd and import the image in to PhotoShop, I also found no issues importing the PSD this way.
1 Comment
Q
QA Team
said
about 1 year ago
Answer
Hi Richard,
Richard Funnell
Hi Richard,
QA Team
Hi Richard,
Keyshot 8.2.80 / Out of memory (requesting 4294967214MB) This may cause instabilities
Color Picker Tool not working in 9?
Accessing Context Menu in KS 9.1.98 with single button mouse
Critical Bug by 3dsMax plugin
Can't Drag Materials from Cloud Library
Crash on “Finishing” after rendering animation
Not able to export FUZZ Geometry to FBX/OBJ
Cuda error: cudaErrorDevicesUnavailable (all CUDA-capable devices are busy or unavailable) Device : GeForce GTX 1070
See all 41 topics
