KeyShot Support Portal
Welcome
Login
Sign up
Home
Solutions
Forums
Enter your search term here...
Search
New support ticket
Check ticket status
Start a new topic
Discussions
Luxion Support Forums
General Support
Answered
TEXTURE
t
tim sumner
started a topic
10 months ago
how does you tile a texture so it doesnt look like a chess board?
(13.4 KB)
Best Answer
E
Erik Williams
said
10 months ago
Hello Tim,
If you are using a 'bump' texture, you can change the height and width by double clicking the model to open the 'material' window.
From here select 'textures'.
Select the 'bump' texture and scroll down to 'size and mapping'.
Here you should see the 'Use DPI for size' checkbox is marked.
Uncheck the box to be able to modify the width and height of your texture.
You can also do this by changing the 'Size' dpi directly.
I hope this helped explain things. If there is anything else I can help you with please let me know.
Erik Williams
Customer Support Specialist
1 Comment
E
Erik Williams
said
10 months ago
Answer
Hello Tim,
Erik Williams
Login
or
Signup
to post a comment
More topics in
General Support
too much light
tiling
Spiky Shadows and Reflections
See all 77 topics
tim sumner
Erik Williams
too much light
tiling
See all 77 topics
