After updating to version 9.3 yesterday it looks like render pause no longer functions properly.
When I click on the pause button, the huge "PAUSED" text appears in the middle of the screen, but the samples keep climbing in the bottom right corner and the CPU/GPU load in Task Manager stays the same.
Best Answer
E
Erik Williams
said
10 months ago
Hello Derek,
Can you go to the 'edit' tab in the top toolbar, then 'preferences'->'general'?
Here you will see 'Pause Real-time Render after', followed by some options.
What number is shown next to 'samples?
If you change the number of samples to '5' and pause the real-time view, does it stop?
If it doesn't stop right away, give it a moment
If it does stop, how many samples are collected when it stops?
If it stops at 80 samples, this is an issue we have recently discovered with the platform. In GPU rendering mode, real-time samples are collected in multiples of 16. The sample count will finally stop once it believes the correct number of samples has been collected.
CPU rendering does not experience this issue.
We are investigating this issue now and hope to have it resolved as soon as possible.
We have looked into this issue and it has been solved in the KeyShot 10 release.
If you have purchased KeyShot 9 after October 18th or have a maintenance contract with us, you may be qualified to upgrade to KeyShot 10 for free.
If you are still experiencing this issue, please reach out to our team at sales@luxion.com to see if you qualify. Explain to them the situation and how it affects your work.
Our Sales Department will look into this and see what we can do for you.
Thank you for your patience on this matter.
S
Seth Bullington Short
said
2 months ago
I noticed this same bug in KS 9.3.14. When rendering GPU mode, the pause button doesn't pause.
In fact it will continue to process multiple frames of an animation even when it's supposed to be paused.
Pause works fine in CPU rendering mode.
D
Derek Heming
said
10 months ago
I set the "Pause Real-time Render after" to the minimum amount of 16 samples. With GPU Mode turned on, real time preview never stops. With CPU Mode turned on it does indeed stop at 16 samples.
This exactly mirrors the problem in render output: GPU Mode never responds to pausing, but CPU Mode does.
E
Erik Williams
said
10 months ago
Answer
Hello Derek,
Derek Heming
Windows 10
GPU mode
- Oldest First
- Popular
- Newest First
Sorted by Newest FirstErik Williams
I apologize for the delay.
Derek Heming
Erik Williams
Keyshot 8.2.80 / Out of memory (requesting 4294967214MB) This may cause instabilities
Color Picker Tool not working in 9?
PSD Screenshot gives program error in Photoshop
Accessing Context Menu in KS 9.1.98 with single button mouse
Critical Bug by 3dsMax plugin
Can't Drag Materials from Cloud Library
Crash on “Finishing” after rendering animation
Not able to export FUZZ Geometry to FBX/OBJ
Cuda error: cudaErrorDevicesUnavailable (all CUDA-capable devices are busy or unavailable) Device : GeForce GTX 1070
See all 43 topics
