I've been struggling to import an Assembly STL file from Solidworks to Keyshot.
Reason being is that there is a part in my assembly that is missing, I got this part from the internet which was made from ZBrush (because it's too complicated to make). When opening this specific part into Solidworks I'm unable to define any features it's just called a 'Graphic'. Does anyone know how I'm able to get this graphic up on Keyshot?
Best Answer
E
Erik Williams
said
9 months ago
Hello Lydia,
Unfortunately that is something you will need to discuss with Pixologic and ZBrush support. They should be able to help you define the missing part, or at least point you in the right direction.
I apologize for the inconvenience this has caused you. If you get this taken care of and are still having problems importing it to KeyShot, please let us know.
Referencing your Ticket ID#:8819
Erik Williams
Customer Support Specialist
1 Comment
E
Erik Williams
said
9 months ago
Answer
Hello Lydia,
Lydia Chutpinyacoub (student)
Hi to all!
Erik Williams
TEXTURE
too much light
tiling
Spiky Shadows and Reflections
See all 82 topics
