For scenes like this you would want to enable 'caustics' in your Lighting settings.
When rendering, try using 'Max Samples' or 'Max Time' instead of 'Custom Control'. This should provide you with better results.
Let me know if this helped.
Referencing your Ticket ID#:12349
Erik Williams
Customer Support Specialist
1 person likes this
J
Jessica L.
said
8 months ago
Dear Erik, Thanks for your quick reply. I will try your method.
Besides, For this "liquid and bottle" 3D, what is the right way to manage the liquid surface and inner surface of the bottle? Exactly touch? or cross each? or leave a small space between them?
Jessica L.
hi,
I got a problem when I do the transparency&cloud material and solid material.
please see my problem pictures below.
I tried 2 ways:
1, the 2 touching surfaces have no space
2, the 2 touching surfaces overlap a little bit, such as 0.1mm.
the 2nd way works better, but it still has some strange dot on the surface on the final rendering pics. see below.
Thanks in advance for your supporting.
- Oldest First
- Popular
- Newest First
Sorted by Oldest FirstErik Williams
Erik Williams
1 person likes this
Jessica L.
Dear Erik,
Besides,
Thank you:)
TEXTURE
too much light
tiling
Spiky Shadows and Reflections
See all 83 topics
