For a more accurate representation, I would recommend using the Three-Point Perspective. You can also use the 'ground grid' to get a better idea of where the ground is vs. your model.
You may want the top blue line to follow the wall to get a better representation of Screenshot2, but that is entirely up to you.
Be careful when adjusting your axises as your models rotation will change accordingly.
Referencing your Ticket ID#:12439
Erik Williams
Customer Support Specialist
1 Comment
E
Erik Williams
said
almost 2 years ago
Answer
Hello Richard,
It appears you have the gist of it.
Richard Follett
I have always struggled with this so after some help as I think this is a very simple example.
have i matched the blue and red lines correctly?
focal length on photo is 28 when checking
Erik Williams
TEXTURE
too much light
tiling
Spiky Shadows and Reflections
See all 163 topics
