I am trying to apply a label to a single surface, as I have been able to do in past versions of Keyshot using the "normal" mapping type.
I see that's now gone and "planar" is the closest option. Label is applied on the X-plane and shows up on multiple surfaces of the same part. Changing the depth slider does nothing.
I have read that a workaround is adding a surface to the model but I don't want to get in the habit of adding unnecessary surfaces in my models to accommodate keyshot.
Is there a direct way to control surface label application that I'm missing?
Jason Sellers
Thanks.
1 person has this question
