Is there a way to update a model instead of importing a new version of the same file name? Previous versions of Keyshot had this option on the import button but I cannot for the life of me find that in 9.
Best Answer
E
Erik Williams
said
almost 2 years ago
Hello Jason,
Are you experiencing this issue using the plugin or when importing directly into KeyShot?
Also, are you experiencing this issue with all imports or just a few in particular?
If it is happening to specific files, can you send us a copy of the CAD file?
If it is an assembly please include all parts in a zipped folder. You may send it securely via our WeTransfer site, link here.
Please make sure to include the following in the message field for your upload:
1. Your Ticket ID: 13469
2. The Case Subject: update model vs import
3. Support Agent: Erik Williams
This will allow us to track your files in our system.
More often than not though, this is a result of KeyShot and SolidWorks being out of sync.
Have any file names or file paths in any of the parts of your model been changed?
If this is the case, importing a fresh copy instead of the update will get around this issue.
Erik Williams
Customer Support Specialist
Referencing your Ticket ID#:13469
1 Comment
E
Erik Williams
said
almost 2 years ago
Answer
Hello Jason,
Jason Sellers
Erik Williams
TEXTURE
too much light
tiling
Spiky Shadows and Reflections
See all 165 topics
