Double click on objects and in menues is not working KS 9.3.14
p
phos4
started a topic
almost 2 years ago
Since yesterday this "bug" is annoying, whenever I double click on an object in KS to get to the material tab of that object, nothing happens. I have to instead right click -> edit material. And once I am in the material tab, when I want to add a texture for example, the same happens, double click will not react and I have to right click and select from the menu.
phos4
Any thoughts on what is causing this issue?
