It is possible that one or more materials in the scene are causing this issue. Have you downloaded or added any materials recently? The download may not have completely finished.
You can open the scene in CPU mode, then hide all of the parts and reveal them one by one until the issue pops up again.
Once the material(s) have been found, you can delete and re-download them.
Erik Williams
Customer Support Specialist
Referencing your Ticket ID#:13998
E
Erik Williams
said
5 months ago
Thank you Rich,
Can you confirm that your GTX 2060 is your preferred GPU?
If not, you can enable this through the following:
1. Open the Nvidia control panel.
2. Go to Manage 3D settings.
3. Go to the Program Settings.
4. Select KeyShot from the Drop-down.
5. If it is not available add the KeyShot.exe manually by browsing to it below.
C:\Program Files\KeyShot #\bin\keyshot.exe
%USERPROFILE%\AppData\Local\ in the KeyShot #\bin\keyshot.exe
6. Select your Nvidia graphics card under preferred graphics processor.
7. Click Apply and restart KeyShot.
Let me know if this helps.
Erik Williams
E
Erik Williams
said
5 months ago
Hello Rich,
To better assist you, I'll need to gather additional information. Please provide me with your DxDiag file.
How to create a DxDiag log
Press the Windows Key + R
Enter "DxDiag" and run the command
Press 'Save all information' and save the file in an easy to find location
Reply to this email and make sure to include the files as an attachment.
Rich Follett
get this on large files.. running KS 9.3.14 and windows 8.1 64 bit.
is this a known issue?
thanks
- Oldest First
- Popular
- Newest First
Sorted by Newest FirstErik Williams
Erik Williams
Erik Williams
TEXTURE
too much light
tiling
Spiky Shadows and Reflections
See all 78 topics
