Start a new topic
interactive 3d pdfs?
Is it possible to create interactive 3d pdfs from Keyshot 10?
Hello Erich,
With the pro version of KeyShot 10 you have the ability to export your files as a Glb/Gltf.  This file format can be used in software like PowerPoint and other document applications that can read advanced 3d file types.
Referencing your Ticket ID#:21529
Thanks,
Justin Adams
Support manager
Luxion Inc
15143 Woodlawn Ave
Tustin, CA 92780
http://www.keyshot.com
Hello. Thanks for the reply. Can these GlB/Gltf files be used to create an interactive 3d pdf?
Hello Erich,
They can, you will just need to check with the software you are going to use to make the PDF if it will support this type of file.
GLB/Gltf is a universal file type so it should work.
Thanks,
Justin Adams
Support manager
Luxion Inc
15143 Woodlawn Ave
Tustin, CA 92780
Can you guide me as to the steps on how to do this? I was hoping to be able to use Adobe for this, but don't know how it would be done.
Looks like Adobe Acrobat will only accept U3D file formats. Can you please add this capability into the next release of Keyshot?
Login to post a comment
