Thankyou.
I do this routinely in CAD by splitting the solid model into the proper number of veneer layers. Import to KeyShot and apply materials as you would normally.
Cheers
~M
Hi Erik, still cannot find the split/edit surfaces function. Is this available only on the pro version? I have the HD or basic version.
Thanks Erik, that all makes perfect sense, but when I right click on a model, I dont get the same options.
The split object functions are not available.
Ticket ID#:22651
Alex Morgan
How do I go about doing plywood edged? I have some simple planar rectangular parts I need to make in plywood. I have both the files for the top birch face and the laminated edges but do not know how to separate the surfaces of the parts to apply the two different finishes. How do I go about applying two different finishes to the same part?
1 person has this question
