The question is probably very easy to answer, but unfortunately I can't find a solution. I would like to set my own resolution, which according to the manual works by selecting the option "Edit user templates" (Benutzervorlagen bearbeiten) from the drop-down list "Preferences" (Voreinstellungen) Unfortunately, I can't find the drop-down list or the option.
I am using Keyshot 9 on a Mac OS 11.1 in German.
Maybe it's just a language problem, the link "Manual"(Handbuch) leads me to a "404 not Found" page, and when I manually navigate to the manual I only find the 10th manual in German, the previous manuals only in English, so maybe the menus are just called differently. macos/deepLFree.translatedWithDeepL.text
1 Comment
Francisco Carrera
said
over 1 year ago
Hello Info,
You would be able to find all the Manuals for KeyShot from this link here.
The page in the manual that you are looking for on resolution is located here on this link.
If you go to Project Window and then go to Image click on the Presets drop down menu, and you can select Edit Customs and this should allow you to make the resolutions that you wanted.
Info
Hello everyone,
