Do not merge your KeyShot 9 resources with KeyShot 10.
Once fully installed, please send us a request file using serial code - LUXIONKEYSHOTTESTING to receive a temporary license for you to use and see if the issue has been solved.
How To Create A Request File:
1. Start KeyShot and select "Activate your license" from the registration wizard.
• Note: If you are currently in the "Demo" mode, then open the registration wizard from Help(Windows) or KeyShot (Mac) > Register License.
3. Enter your information and click Continue.
4. Enter your serial code - LUXIONKEYSHOTTESTING
5. Click Save request file and send that file to us as an attachment.
Ethan Chow
Hi there, I've been having a lot of trouble trying to render in GPU using a file I had before. It gives me the following error:
(02:00:10) Cuda error: cudaErrorIllegalAddress (an illegal memory access was encountered)
Device : GeForce GTX 1080
I have updated my drivers, checked there are no toon materials and occlusions, but I can't seem to find the problem. Can someone help?
