When i want to start an XR rendering in GPU mode with my 2060 Super with about 1000 frames, there is weird stuff happening. When i start to render it in 3000x1500, the render window stays black and keyshot doesnt get over one sample. When i lower the resolution i got to round about 40 frames untill the same freeze occures. There is no error or stuff from keyshot. When i try to close the window afterwards, the cleanup dialog also just doesnt go away.
Maybe there is a solution, doesnt looks like the GPU is eating the RAM but i still didnt found a workaround.
Did you make any changes to any cameras while the KeyShotXR render dialog was open?
Lets start with the basics and make sure your GPU drivers are updated.
We recommend driver version 456.55 and up. We can not recommend drivers of version 450.xx and below as there are known issues in KeyShot with those drivers.
Ben X
Hi!
Greetings
