Start a new topic
10.2.102版本,工作室批量渲染命名问题
新版本,可以把工作室作做单一的任务来渲染,但是文件名也是单一的,无法把工作室名作为文件名来用,是我操作的问题,还是以后的机制就这样了,很不方便哦
1 person has this question
Hello yzyz,
Yes we have noticed that when adding multiple studios, they are rendered using only the actual job name and increase the count.
Previously it would include the studio name in the output name.
Our team is looking into this now.
In the meantime, rendering using the Scripting Console should get you around this issue.
For more information on how to use the Scripting Console, please go to https://manual.keyshot.com/manual/scripting-2/ for more details.
Thank you for your patience while we work to solve this issue.
If you need any help with your script, please let me know.
Referencing your Ticket ID#:36481
Erik Williams
Customer Support Specialist
2 people like this
非常感谢您的回复,以前没有用过脚本也了解的比较少,有时间会试试看的。 祝keyshot越来越好~~~
I'm running into this issue as well. Adding studios to the render queue, it doesn't retain naming conventions ("active model set"_"studio name" for example). It also throws the rendered images into a subfolder.
Login to post a comment
