Start a new topic
transparent render error for area light
Hey, people
i am facing a issue with the transparent render which has area light at the bottom of the model for illumination, i have unticked the "visible to camera" option and it works fine in non-transparent images, but when i go for transparent render, with same setup the output has that area light in it , and i dont know what to do know with this
Hello,
Please send us your scene as a ksp file.
To save a ksp file:
  1. Open your scene.
  2. Go to File > Save Package.
  3. Name your file.
  4. Include Ticket number.
Referencing your Ticket ID#:37764
Erik Williams
Customer Support Specialist
Hello Prakhar,
Your plane was 'below' the ground platform. Moving it and your model above ground will solve the issue.
Let me know if this works for you.
Erik Williams
Hello prakhar,
What I sent was a rough fix, but it does appear your ground plane was created in the original CAD program and was not moving smoothly along the axis points. Creating a new ground plane in KeyShot or using a smaller geometry to act as your light source will do the trick.
Erik Williams
Login to post a comment
