1) What are some good resources for outdoor lighting? When using HDRI Is it better to light with 4k 0r 16k maps?
2) what is the preferred Keyshot material workflow, Metal Rough or Spec Gloss?
1 Comment
E
Erik Williams
said
12 months ago
Hello Sadicus,
A colleague of mine recommends hdrihaven.com for free HDRIs. They have a good catalog of Outdoor HDRIs as well.
All of these will produce equivalent results, but since Roughness is the standard material parameter in Keyshot, "Matel Rough" will provide the quickest workflow.
I hope this helps. If you have any other questions, please let me know.
Referencing your Ticket ID#:38804
sadicus
