Start a new topic
10.2.113 version has a BUG, after the set second environment is saved, the next time to open the first environment will jump to the list.
10.2.113版本有BUG,设置的第二个环境保存后,下次打开第一个环境会跳转到列表。
1 Comment
Hello,
Thank you for contacting Luxion Support.
To better assist you, I’ll need to gather additional information. Please provide:
  1. Computer make and Specs:
    • Manufacturer (Dell, Toshiba, HP, etc..)
    • Windows/Mac OS version
    • Graphics Card model
    • Processor model
  2. Step-by-Step instructions to re-create the issue you are seeing
    • Open KeyShot scene
    • Go to Project, Camera and add a Camera
    • etc…
  3. Screenshot(s) showing the issue that you are seeing
  4. A .ksp file of your scene
To save a ksp file:
  1. Open your scene.
  2. Go to File > Save Package.
  3. Name your file.
  4. Include Ticket number.
Referencing your Ticket ID#:39085
Erik Williams
Customer Support Specialist
Login to post a comment
