hi, thanks for the prompt reply .
I get a black render when using the gpu on every single scene, even a simple cube/the keyshot scenes included. drivers updated, even tried older drivers - tried to reinstall - still doesnt work.
RTX 2070
intel i7 - 8700 cpu @3.20GHz
64gb ram
windows 10
Hi, i have been facing the problem of GPU errors multiple times and stressed to the point.
Getting black renders for the GPU renders and getting crashed in midway with log error CUDA MISALIGNED ADDRESS. The machine works with a DISPLAY 2 set of Nvidia Geforce GTX 1650.
With updated drivers and repeated uninstalling of keyshot , I'm not able to solve the problem.
Hello ArAvind,
What version of KeyShot are you using when experiencing this issue?
Is the scene you are experiencing this issue with using any displacement materials?
Your previous email stated you were using a Nvidia 2070, but this message shows a GTX 1650.
If using a newer version of KeyShot, this card may no longer be fully supported.
retroafro1
Hi, My renders (GPU) have randomly started to be all black - also the sample count is sky high, like billions.....please help as i need this for work!
