Start a new topic
Geometry view doesn't show objects properly
Hi I think I touched something and now the geometry view only shows the imaginary  cubes that objects occupy. How do I change this back to normal?
Just so you know the scene it's a chair, a table and some lights....
Hello Fernando,
If you are still experiencing this issue, please send us your scene as a ksp file.
To save a ksp file:
  1. Open your scene.
  2. Go to File > Save Package.
  3. Name your file.
  4. Include Ticket number.
Referencing your Ticket ID#:42335
Erik Williams
Customer Support Specialist
Thank you, I've just solved it. The program changed the view mode to save resources and I've changed it back now
Login to post a comment
