When exporting an OBJ file the object resolution or poly count is too high to have a reasonable size to load into other 3D applications. Does anyone know if the resolution can be reduced or controlled and where are the settings for that are? If I may ask, could someone post a screen grab of the OBJ parameter export settings? Thanks.
michaell@image-base.com
