Start a new topic
Can't edit custom curves on keyframe animations
Hello there!
I have a problem while creating a keyframe animation. Once I create the keyframes, and would like to edit the curves I simply can't click on the curves points. It highlights it with blue for a second, then it goes back green. I can move them if I hold down the LMB, but I can't use the options to change the value or time or choose any options from above which are the premade curves.
I'm using KeyShot 10.2 demo.
Thanks in advance!
Login to post a comment
