Start a new topic
Answered
Keyshot 9 pro stop works on MacOS 12 Monterey
Hello
After upgrading to macOS 12.0.1 Monterey, keyshot 9.3.14 Pro has stopped working, application freezes and quits all the time.
i recive information that keyshot need to be update:
https://www.python.org/doc/sunset-python-2/
how to fix it?
Best regards
Best Answer
Hello Lucas,
You will need to download the latest Python build for your machine: https://www.python.org/downloads/macos/
update this and run KeyShot.
If this doesn't work you can navigate to edit/preferences/general and disable use local python paths
Referencing your Ticket ID#:46360
Thanks,
Justin Adams
Support manager
Luxion Inc
15143 Woodlawn Ave
Tustin, CA 92780
http://www.keyshot.com
1 Comment
Answer
Hello Lucas,
Thanks,
Justin Adams
Support manager
Luxion Inc
15143 Woodlawn Ave
Tustin, CA 92780
Login or Signup to post a comment
