Start a new topic
Problem with the cutaway material
HI, I have a complex model that I want to cut through. So I pushed a cube over it and applied the cutaway material. However, the model is not cut cleanly. A kind of shadow remains from some parts.
If I choose a cutaway material with caps, the shadows are the color of the caps. If I choose the material without caps, the shadows are gone and everything is fine.
Does anyone know that and can tell me how to get rid of this?
I have the same problem -- did anyone give you a solution?
Hi Bill,
no. But I found out that my model wasn't accurate. So I could delete the surfaces that made problems and everything was fine.
Thanks Sonja - looks like it’s intersecting surfaces that causes issue.
Login to post a comment
