I'm switching from v6 to v10. Do you know why the area light power setting is ghosted and inactive? How do I adjust the power setting? This rendering is in "basic" light mode. Please see the attached screen grab.
If you apply a specific area light with a designated output you will not be able to adjust the power output.
If you select area light for the material output then you can control the light power output.
You might need to change the material to something else first like plastic or diffuse, once you have done this then you can use the drop down in the material tab to switch it to area light.
Referencing your Ticket ID#:51296
Thanks,
Justin Adams
Ken Reita
Hello:
KS 10.2.113
CAD: KeyCreator
Thanks,
Ken
