Start a new topic
Stitched seam
Does anybody know how to render a stitched seam on leather or cloth?
I found a stitch brush on the Poliigon website with the following link:
https://www.poliigon.com/brushes/stitches
Can this brush be used in Keyshot?
Thank you
1 Comment
Hello Maarten,
While I am unfamiliar with that particular texture, there should be no problem with it as long as you have also downloaded the
I hope this helps. If you have any questions please let me know.
Referencing your Ticket ID#:52327
Erik Williams
Customer Support Specialist
Login to post a comment
