KeyShot Support Portal
Welcome
Login
Home
Solutions
Forums
Enter your search term here...
Search
New support ticket
Check ticket status
Start a new topic
Discussions
Luxion Support Forums
General Support
Dual Xeon x99
S
Samuel Herrmann
started a topic
about 1 year ago
Hello, someone could inform if the Keyshot is compatible with Dual Xeon x99. Thanks
2 Comments
Oldest First
Popular
Newest First
Sorted by
Oldest First
E
Erik Williams
said
about 1 year ago
Hello Samuel,
As long as the computer meets the system requirements listed at
https://www.keyshot.com/system-requirements/,
it should be able to run KeyShot.
I hope this helps. If you have any questions please let me know.
Referencing your Ticket ID#:53756
You are able to check the status of your ticket by visiting your ticket portal by
clicking here
Erik Williams
Customer Support Specialist
E
Erik Williams
said
about 1 year ago
Hello Samuel,
CPU will use all assigned processors when working.
GPU Mode does cover Multi-GPU rendering. You can find more information about NVLink and other processes at
https://luxion.atlassian.net/wiki/spaces/K10M/pages/1601249616/GPU+Mode
Thank you again for your questions. Let me know if there is anything else I can help you with.
clicking here
Erik Williams
Login
to post a comment
More topics in
General Support
TEXTURE
too much light
tiling
Spiky Shadows and Reflections
See all 197 topics
Samuel Herrmann
