Start a new topic
Rotating the Gizmo on an Object
I was just wondering if there's a way to reorient the gizmo when moving, rotating, etc. an object. Sometimes I get CAD files where the direction of the x, y, and z coordinates are not what I'd like them to be, but I can't figure out how to adjust them. Any help would be appreciated.
1 Comment
Hello Raymond,
What some people do in this case is to select a piece of geometry by navigating to Edit/Add geometry.
move a piece of geometry to the center of the object and in the move option you can select this as the pivot point.
This will re orient the pivot for you, make sure to hide the geometry from the camera so it is not seen in your scene.
Referencing your Ticket ID#:55788
Thanks,
Justin Adams
Support manager
Luxion Inc
15143 Woodlawn Ave
Tustin, CA 92780
http://www.keyshot.com
Login to post a comment
