Start a new topic
is it possible to animate/move a texture or label in KS?
 so I have a simple .png I want to move across a flat surface - is this possible?
I can see colour fade and curve fade but not move...
I am sure it is possible - many thanks as always
I would place the label on a separate plane in the same size of the label and animate this part. That is the easiest way with full control.
Hello Rich,
You can using video mapping https://www.youtube.com/watch?v=pvNkfuAoonU
This video is in regards to displacement mapping but it follows the same principle using video mapping to drive the animation
Referencing your Ticket ID#:55937
Thanks,
Justin Adams
Support manager
Luxion Inc
15143 Woodlawn Ave
Tustin, CA 92780
http://www.keyshot.com
Login to post a comment
