Start a new topic
Animation File Path Not Being Saved
Hi there, on KS11.1 beta still. I noticed when I set the rendering destination folder in the offline render output dialogue, it's not being saved. I will render files to that folder. Save and re-start KeyShot and it seems to revert to default render destination. I'm seeing this specifically for the 'frames' file path in the Animation output dialogue.
1 Comment
Hello Will,
Thank you for the update.
I am unable to reproduce the issue, if you could give me a step-by-step guide as to what exactly you do when this issue occurs.
There was also a fix to some file path issues we've seen in the latest BETA build.
I am sending it to you over our WeTransfer channel.
Give this build a try and let me know if you are still experiencing this issue.
Referencing your Ticket ID#:58923
Erik Williams
Customer Support Specialist
Login to post a comment
