Start a new topic
Export labels to GLB
hello,
Sorry if my English is not very good.
I did a modeling for the creation of an nft, so exporting in glb format. I simply can not export my labels which are on my material ( which opens it well ). For information I am on KeyShot 10.1.79
is that you have a solution because I can only go through labels for the rendering I want.
Thank you in advance for your response
Hello Kevin,
If you could, first please try upgrading to the latest KeyShot 10 release (10.2.113).
If this fails, what are your export settings and what viewer are you using to confirm the glb file?
If you are not using the 3D Viewer, give that a try and let us know if the render now looks correct.
If all of this fails, please send us a copy of your scene as a .ksp file.
To save a ksp file:
  1. Open your scene.
  2. Go to File > Save Package.
  3. Name your file.
  4. Include Ticket number.
Referencing your Ticket ID#:60022
Erik Williams
Customer Support Specialist
Hello Kevin,
The triangle issue is the primary cause.
Fixing this should get everything working as intended.
Erik Williams
Login to post a comment
