Start a new topic
The core 12 is only 40% utilized when rendering
1 Comment
Hello,
First can you confirm that you have your CPU at 100% when rendering?
If so, please check your computer's power mode and see if it is set for performance or is balanced.
If balanced, set it for high performance and see if that increases your CPU usage.
Lastly, and yes it is cliche but try restarting your computer to clear any cached programs or applications that might be slowing down your KeyShot rendering.
Referencing your Ticket ID#:61834
Erik Williams
Customer Support Specialist
Login to post a comment
