I'm working through the Animation tutorials from Will Gibbons now, but this happens all the time in Keyshot. I use the Geometry view and the Gizmo hides behind the object itself that I am attempting to move. It can happen in all views (wireframe, shaded, etc.) When I pivot around, I can expose the Gizmo again from time-to-time, which I need to do as that is the only way to find it. But depending on the point of view it usually is hidden. Sometimes, even when visible, I need to turn off Translate and Rotate, for example, to be able to see the Scale.
I have found that this is not dependent on the geometry, or the file. It happens all the time- just seems to be inherent every time I use the Move Tool Gizmo... which is all the time.
Thank you.
1 Comment
Justin Adams
said
about 1 month ago
Hello Lawrence,
This is something that we are aware of and will have fixed in our next update to 11.2.
We are aiming to release this shortly in the next month or so.
Referencing your Ticket ID#:65132
Thanks,
Justin Adams
Lawrence Kaplan
Keyshot 11.1.0
MAC Pro OS Monterey 12.3.1
Thank you.
