Start a new topic
resetting texture positions
if you duplicate a texture it can happen to reset the position of texture which was duplicated from. or you start to set new settings on duplicated texture and decide to undo some actions, it will reset position of both textures
1 Comment
Hello Jeff,
If this is happening in the material graph nodes, its more than likely the textures are synced.
​After applying the first texture to the node, scroll down and if sync is highlighted, click to deactivate it.
That should solve the issue.
Referencing your Ticket ID#:68402
Erik Williams
Customer Support Specialist
Login to post a comment
