keyshot deleting all studios if you delete some of them
J
Jeff
started a topic
about 1 month ago
if you are working on a new projekt wich is similar to an old one you copy and rename the file. then duplicate some studios und set some new models while using old camera and enviroment settings. if you are finished and start to clean up the file by deleting old studios and modelsets it works fine but if you close and reopen the file, all studios have been deleted so you need to create them again...
1 Comment
E
Erik Williams
said
about 1 month ago
Hello Jeff,
My apologies but if you could give us a detailed step-by-step guide as to what you are doing as well as the current version of KeyShot you are on and your Operating system, it would give us a better idea of what exactly is going on.
Computer make and Specs:
Manufacturer (Dell, Toshiba, HP, etc..)
Windows/Mac OS version
Graphics Card model
Processor model
Exact KeyShot Version (e.g. 8.1.80)
CAD Software and version or year (if applicable)
Step-by-Step instructions to re-create the issue you are seeing
Open KeyShot scene
Go to Project, Camera and add a Camera
etc…
Screenshot(s) showing the issue that you are seeing
Referencing your Ticket ID#:68403
Jeff
