Unable to split objects or surfaces in 11.2.1 [4.5.35]
J
James Hausman
started a topic
7 months ago
I have either imported step files, imported solidworks files, or synced solidworks files into Keyshot 11.2.1 [4.5.35], and I have been unable to spit object surfaces or split separate objects. Also, when i put my mouse over an object in the scene window, it used to pop up a little preview of that object right next to the mouse cursor. Now that little preview window is just black.
In all previous version I never had a problem with this. However, now I get the nurb object warning, which I'm ok with, and I have even re-tessellated files. Every time I pull up the split object surfaces window, there are not triangle surfaces like before, it's just showing grey blobs, which I can't select.
When I pull up the split separate objects, it just pulls up a blank screen, and I can't do anyting.
James Hausman
