Please ignore that very unfortunate typo :D
Sorry, now i understood, yes both lead to the same Folder:
Hi Erik,
Thanks for the response, I deleted all Keyshot Plugin Folders. Still the Plugin shows up when opening Rhino. Somehow this Folder in %AppData% keeps installing itself after starting Rhino :
I followed those steps trying to delete it:
BR/Sebastian
Regarding the OneDrive: The Resources are stored in a One Drive Folder I guess:
But this probably doesn´t explain the selfi-installing Plugin.
BR/Sebastian
I got it unistalled and installed the Keyshot Plugin via the Link you provided, now it says Keyshot 11 instead of Keyshot 9 in the %appdata%.
Now also when clicking the button in Rhino I don´t get the "unknownCommand" message, so thats better but still Keyshot doesn´t open when clicking it.
BR/Sebastian
But the installation happened locally, i was reading through the second Link you provided. Here is my Installation Path:
Basti D
Hey :)
Eventhough it shows the buttons properly nothing happens when I press them.
Could it be that it is not working with Rhino 7 yet?I tried unistalling and installing several times, restarting the pc and updating Rhino also had no effect.
Can anyone tell me if this combination is working for someone?
Those are my Keyshit Infos:
Thanks in advance :)Basti
