Start a new topic
Render Engine output setting resets every time I return to the tab
Every time I return to the Options tab when exporting renders, the Render Engine option defaults back to Inherit from Real-Time view.
1 Comment
Hello Liam,
What version of KeyShot are you currently using?
Does this happen in between renders or only when closing and re-opening KeyShot?
I believe this is intentional when closing and re-opening KeyShot, but let me know when you have a moment.
Referencing your Ticket ID#: 77708
Erik Williams
Customer Support Specialist
Login to post a comment
