This can definitely be a tricky material; and there a few ways to approach it. If modeling the actual string material is not an option - you will need to UV unwrap the thin pipe and find an image texture to match the cotton string material. These YouTube videos should give some insight on the UV process - as well as some modeling insight.
Frederick Lim
Hi, what is the best way to create a twisted cotton string material? I would like to wrap the material around a thin pipe.
KeyShot Marketing Image tutorial ft. Realcloth Braided Cable
Stereo Splitter Cable 3D Modeling Process Voiceover
KeyShot 9 Quick Tip - Unwrap UV Feature
Jordan Doane
1 person likes this
Camera switch event problem
Keyshot 9: GPU > CPU ?
Making looping animations
Need help creating a diffuser material!
Is it possible to Illuminate a Video Mapped Material?
Plywood edges
Mix materials in real cloth
reflection label
Stitched seam
Animation with multiple objects
See all 20 topics
